Hi everyone,
I am working with an Allen-Bradley Micrologix 1100 PLC on a power system control board. We are planning on installing two exhaust fans on the enclosure door (removable door) to improve ventilation and reduce internal heat. With that said, the exhaust fans are wired by the means of two cables (24v, Com) which will be connected to the control boards corresponding terminal blocks. However, we quite often conduct routine-maintenance procedures or troubleshoot; this requires the door to be completely removed. Thus, I would like to setup a quick means of connecting/disconnecting the cables without having to remove them from the terminal blocks every time. I am thinking of using male/female bullet connectors so that it is quick to connect/disconnect the cables from the power source when required. Does anybody have any better ideas/Agree with me/or have any useful tips?
All replies are greatly appreciated!
Thank you,
24V
Thank you,
24V
