Omron CJ1M CPU 13 communication.. urgent help pleased
goko2rock
Mar 2011
kerala
26
Dear all,
I have one CJ1M CPU 13.. I am trying to communicate using CS1W-CN118 and serial to USB converter CS1W- CIF31, I am using Cx programmer 9.1, when I select auto online, with serial connection checked.. and communication port selected.. I get a error "failed to communicate" dip switch 4 is on. Please help me out of this trouble. Err/alm led is continueously on in CPU
You will also need a C200H-CN229-EU cable.
This cable will connect the CS1W-CIF31 to the CS1W-CN118.
Attached is a pin out for a cable that also works.
Turn dip switch 4 OFF, then cycle power on the cpu.
That will set the peripheral port to default communication parameters.
Solid ERR/ALM led indicates a fatal error.
Once you can connect, you should be able to view the error log to determine the problem.
Hope this will help.
Hi. I also encounter the same problem ERR/ALM is lit. Im trying to connect to plc (CJ1M CPU12) using ethernet but always having error saying to change port setting. I check it and i think it is the right setting which is 9600. Hope you can help me.
what is the name of software for upload cj1 cpu12 and can send for me step bye step file to cominucation with pc?
thankyou
I do the following steps for BACKUP but no COMUNICATION is done between PC and PLC.
Please guide me if I do the wrong thing.
MY SOFTWARE IS CX PROGRAMMER 9.1
1:
Select PLC type CJ1M-CPU12 and select COMMINIUCATION type NV-THRU (SERIAL PORT)
2:CLIC TOOLS THEN PLC BACKUP TOOLS THEN CLIC BACK UP FROM PLC AND OK
BUT COMINUCATION IS NOT OK
PLEAS HELP ME
Try connecting directly to the plc, not through the NV.
Direct cable would be CS1W-CN226 to the peripheral port.
USB to serial adapter would be CS1W-CIF31.
Thanks .
That is, this type of cable should be used to connect to the serial port?
Because I can easily connect to drives from my usb to serial cable, such as a SSD PARKER DRIVE.
I could not connect to the PLC exactly with USB TO SERIAL. Do you think I may not know how to upload?
Is there a MANUAL that fully explains the UPLOAD steps?
Hi I have a plc omron CJ1M connected to a HMI this is a reconditioned panel in which this plc is connected. But the touch screen of the HMI is not...
3,576
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
244
hi dear all hope you all are fine I have a problem with my CJ1M cpu11 ETN. it stop communication with PC over ethernet. ETN unit all indications...
163
Hello everyone. I am new when it comes to Omron PLCs. Currently I'm uploading program from CJ1M PLC using CS1W-CIF31 cable only. I connected the...
158
i have been trying to connect to omron cj1m via peripheral port(USB to Serial), but there isn't any sign to show that it has connected, so am...
318
