Factory Talk ViewSE Data Logging to File - change of datatypes
mzurtak
Jun 2015
Canada
I have a clients machine running Factory Talk View SE release # 8.00
I have set up trending and data logging which has been working correctly for the past 6months until 48hrs ago when the data logging to file set has changed half of the tag data types in each set from analog tags to string tags. I confirmed this by looking at the log files. Creating new log files using the "NewDataLogFile" command did not fix the problem.
Firstly how would I go about changing the tag types back to Analog tags? Would this need to be required to be done in the 'SQL Server Database Primary Data File'.
Secondly does anyone know why the data types would have changed and are they set by data coming from the PLC? Becasue I cant set the data type for each tag in the Data Log Model setup.
So called tech support... it is a known problem for FactorTalk View SE. It is caused when the Sever looses connection to the PLC and when reconnect some of the tags comeback in as Strings rather than analog floats.
To fix restart the server/computer.
Well, after straightening out all of my Factory Talk password issues, I decided to install the patch roll-ups for RSview SE. The installation...
6,332
93
Hi Guys, Looking for someone well versed in VBA that can either tell me a certain naming convention or point me in the right direction (I'm a...
60
Hi- I am configuring an alarm and event server to display 1 current alarm at a time on a big display. Having a few issues The alarm doesn't...
59
Hi Friends; I have a red Explanation Mark on Factory Talk Directory in Task Bar. Before Update the windows and installation of AutoCad it works...
152
