SLC 504 to ControlLogix MSG on DH+
The data table format of PLC-5 and SLC500 Integer "N" files are 16-bit "INT"
The default integer data format on ControlLogix is 32 bit "DINT". Is your message data arrays in your ControlLogix configured as a data type of "INT"?
Has anyone ever seen this before. I have a SLC 504 running a very small program and it would seem the TON wouldn't start counting using the...
24
4,692
Probably a silly question and asked a hundred times already, but i tried to do some searching here and couldn't find this question. I have 502's...
3,000
I have a SLC504 in the field that is communicating DH+ to several other SLC504 and the RS232 port is communicating to a panel view plus 1000. I...
1,271
As part of an upgrade I am working with 7 different SLC programs. I had the first program in a test controller in my office running and...
2,505
Hi, I am having an issue on one of my station. It won't communicate after the power shutdown. If we cycle the power it is communicating , but I...
1,459
