SMC log error in Application Server 3.1 for ControlLogix Tag
Controls_Fan
Mar 2011
houston
Hello All,I have the following error in the smc log file .............................................Unable to add item 'clxEthernet_AOS2.clxEthernetBridge_SSSpri.clxBackPlane_SSSpri.clxProcessor_SSSpri.FS_3903.OverrideConfirm' with access path 'clxProcessor_SSSpri_SSS_CLX'........................................................................................................ (I read about the similar topics here and got to know that it should be because incorrect adressing between the tags - but I am not sure on how to check the adressing for the tag and get rid of the error. I assume that DA server being dynamic it should not really be reading the adresses of individual tag and the error is only for certain tags so I am not sure)........................................................................................................Any Insights?Thanks
Hello, I have a Allen Bradley SMC Dialog Plus that i communicate to through a Scanport 1203-EN1 and i'm getting this error below I/O Faulted...
1,316
Hello I'm in the process of programming SMC dialog soft starters to communicate with PLC-5, via the block transfer method. They were setup for...
2,066
Hi, I have problem with my SMC Log viewer. System: - MS Win XP SP2 - DASMBTCP driver - Wondeware InTouch 10.0 - disk pace on computer 270 GB -...
4,930
Hi, I want to start 150 SMC Flex from Studio 5000. I have the AOP and P SMC flex AOI imported in my program. I have also set the logic mask to...
307
Hi everyone, We are having Fanuc 16 i CNC system. I need to interface SMC ex260 SEN-1 ethernet valve module with the CNC . Does anyone know the...
357
