Installing S7 Lite on a Vista or Windows 7 machine ?
Have a search here - I remember someone commenting that there is a file that you can change that looks for the Windows version. You could try that - it may not work of course.
The other issue you may haver is that the drivers may not work in Vista or Windows 7.
Also do a search on MrPLC - I may have seen the comment there.
I succesfully installed Step 7 lite on windows 7 but was an Virtualization technique, which consist in using Virtual-PC (the package for using diversing OS environment), firts one must to downloading Virtual PC and after that the OS system itself, then i did downloaded Windows XP Mode (for Windows 7 32 Bits), (all of that is free of charge, as well as Step 7 Lite ).
With the virtual enrionment setted allready, can install Step 7 Lite SP 4.0
Hope this could be helping notes, Regards!
I am trying to install ConfigEd lite for SSD Drives. I am using a Dell lattitude D830 with XP pro SP 2. I install the CD, and it asks me to verify...
3,533
A new point I/O rack is to be hooked up with the running PLC. In point I/O, it is supposed to be the OA4 card to be installed as per the...
89
During the process of installing Studio 5000 Mini Edition to my new machine at work, it seems as though some things like RSLinx Classic and the...
509
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
691
Hi all, I tried to install Twidosuite on windows 10 but after installing i have the registration link which is not working and also i get with...
570
