Upgrade to Comfort TP1200
Tweeker
Nov 2007
Smalltown
79
I am upgrading a MP277 10 inch panel to a TP1200. How do I keep the aspect ratio the same so my screens look correct? I am using TIA Portal V14.
In the settings, there are a variety of options controlling how the screens handle the aspect ratio.
Try a few different options, migrate it a couple times, and see which looks best as a starting point
MP277 10: 640 x 480 pixels.
TP1200: 1280 x 800 pixels.
Unfortunately the horizontal resolution is exactly 2:1 whereas the vertical is 5:3.
So if you choose to automatically fit the objects, there will be distortions. Circles will becomes ovals.
I think I would select a fixed ratio 150 % when converting the MP277 to the TP1200, and then manually adjust all the screen objects one by one (!).
edit: If you select the ratio 166% you should get the closest to fully filling the TP1200 vertically. Horisontally there will be some unused area. You can possibly move the screen objects around to make better use of the horisontal aksis.
Dont round up to 167% as some objects will be placed partially outside the viewing area, and thus will not be shown at all in the runtime.
But where do I change the ratio??? I've looked every where in Portal V14 and cannot find where to make the adjustment.
Thanks.
Here it is, and select the free scale factor.
And keep aspect ratio unless you want circles becomes ovals:
Thank you Jesper.
I changed the settings and downloaded to the HMI. The screens still look the same. In fact, nothing changes when I do a download. I tried to restore the HMI to factory defaults, but I cannot get that to work either.
Hi Experts, I would like to make firmware upgrade from v3.0 to v4.5 (S7-1200 CPU 1215C). Can I do it from v3.0 to v4.5? Do I need to take some...
179
Question to anyone with ideas about my thoughts on upgrading a very vintage timer, which is being used to switch between 2 5hp domestic water...
364
Hi everyone, Kind of new at this, so we recently upgraded our 1769-l32e to the newer 5069-L320erm, i converted the file over and Verify the...
361
Hi Folks, After many, many hours of setup/testing/tuning/etc I'm happy to announce our brand new shiny PLC forum is coming out of beta and...
30
2,036
Looking into maybe upgrading a SLC 5/05. 13 Slot rack. 12/13 populated. DeviceNet to a panelview. That's going in the bin, replaced by...
40
2,387
