I'm facing a strange problem. I was asked to enable a printer on a PLC network, this printer needs to print from a chart recorder attached to some other hardware. I ran a cable, set up the chart recorder to print and it works, that part is successful.
Problem: The chart recorder doesn't print in the format that we need. This is a validated process, and the printout that we are validated for was previously printed by transferring an SD card from the chart recorder to a computer with print software installed off of the network.
I believe that I can do one of the following:
1. Attach a computer with the appropriate software to the network and print the correct format. Or,
2. Attach a computer to the network and print from the web interface built into the chart recorder in the correct format. This is my preferred option if it works.
However, I am unable to navigate to the web interface for the chart recorder on port 80 or 443. I am unable to ping the chart recorder or the printer at the IP addresses that they are successfully printing from.
Why would I be unable to ping or reach the web interface?
