Data Logging with Comfort panel(TP 1200) in TIA PORTAL
sahar
Apr 2017
Tehran
Hello Dear engineers;
I'm using a comfort panel (Tp1200) in conjunction with CPU-300 (Siemens brand) and TIA PORTAL V.13.
I've searched among forums and similar questions that were published but I think there is no clear answer for my question.Finally, I hope that I'm not duplicating this question again.
According to my project,I have to log the status of some tags for two months(this is the important part). So,I created four data logs with Historical data option in TIA PORTAL V.13 based on some calculation of the amount of data and the period of logging. I want to have data log from the first time that the panel will go on . For this reason I changed the acquisition mode of all tags from 'on demand' to 'on change'.
But, How can I stop it after just two months? I want to stop it automatically not by stop logging system function or any push button.
Is there any way to do this work without any scripts?? I mean just with historical data.Is a historical data enough to have a data log from your tags with a deadline??
If writing scripts is necessary for this purpose.please provide me by these codes.
Thanks in advance,,,
I have a data logging application which logs four analog inputs at the rate of 10 hz. I created a pulsing bit at the plc and logs data at the...
1,915
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
52
Hi, Wy we log data in PLC using DLG instruction, when we have option to log data in HMI
75
Hi everyone id like to start by saying im not a PLC programmer so my technical terminology is limited. i would like advice on what software is...
295
Hi All, I am looking for recommendations for a data logging software package that can be used for a simple 1 PLC installation. The installation...
1,378
