WinCC RT Pro / WebNavigator V15.1 and SIMATIC Logon
Hal9000
Jun 2010
London
140
Dear Support,
I am working on a new WinCC Professional V15.1 project. My customer wants to use active directory with my application. I understand that I need to use SIMATIC Logon to support AD, is this correct?
I have purchased 3x WinCC WebNavigator client license. I need to understand what is required to set up Web Navigator to work in this arrangement. I can not seem to find any specific information around this.
In addition there are WebNavigator settings in WinCC RT Pro relating to user groups, but it is not clear as to what the settings actually do. For example;
In WinCC RT Pro> Runtime Settings> Web Navigator> Additional Settings:
The check-box option 'Disable local user groups' - what does this actually do? (see attached image)
The tool-tip states: 'Specifies that the local user groups used by SIMATIC Logon are not assigned to the WinCC groups.'
However, the Info help-files states: 'Define the local user group is disabled on the WebNavigator Server'.
Basically, I need to know if WebNavigator work with SIMATIC Logon when using active directory?
Any thoughts or advice greatly appreciated.
Justin
Is it possible to convert the project in Wincc Professional to Wincc advance?
1,797
I'm little stucked and ask for small help from one with little more experience of vb script. So, I have alarm control window Control1[Alarm...
1,524
Hello, I used TIA Portal v15.0 to create a project with s7 1511 and wincc rt professional and an IO Controller. using profinet to connect all 3...
3,022
Hello all, In an WinCC Professional v15 application I need to filter the alarms by alarm class, not using the filter button on the toolbar of the...
2,568
Hello all, I have a WinCC Project (Pro V16) connected to Information server 2014 SP3. Everything is configured and works as intended using the...
1,489
