Cold Temperature Sensing Instrument Recommendations
billy.nfp
Mar 2022
Canada
Hi all,
Looking for a temperature sensing solution for determining ambient temperature in the frigid Canadian winters. Discrete outputs are fine for my case, which is why my first thought was a simple thermostat - set to around -25 Celsius. I've quickly discovered that in my hour of searching, that simply does not exist.
So, I'd appreciate some recommendations. I'm not adverse to dangling an RTD off the wall of my building, but the thought of a simple $30 thermostat switching an input is very appealing. I simply need to detect when the ambient temperature is below my set point (-25C).
Analog solutions are welcome but discrete is preferred as I wouldn't have to do any extra wiring to make it go :)
Thanks in advance!
Gents, I have a small project that is in an early stage and I need some suggestions. We have two ¾” pipes that carry water one cold one hot...
4,674
What b&r cold restart does? does its erase program permanently?
611
I'm running a distribution terminal on ControlLogix 5580. It's been stone cold where we are and we haven't run some of this equipment since being...
2,400
Hello, I am using the DCS instruction for a simple emergency stop detection. Actually I set the "cold start type" to automatic. This means when...
2,453
Hi all, I am planning to put a AB servo in a freezer environment -20f or worse. My hope is some of you have experienced this and have ideas on how...
2,412
