![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
Hi, I have CX Programmer version 8.01 and have become (didn’t happen with an earlier version) frustrated when I go "online" (typically serial comms via USB to serial and at 19200)and monitor a program - the display freezes / is slow to update when you click between sections of the program or scroll up and down a section using the mouse scroll wheel or slide bar on screen. On-line edits are a nightmare and the program often crashes. I noted that the Comms indicator LED on my USB adaptor seems to be in sync with this freeze as the indicator is off while the screen freezes and then starts flashing when the display un-freezes. I don’t think it is the USB-serial adaptor because it works fine with my Rockwell & Schneider software and wasn’t a problem in an earlier version. What’s going on Omron!
Ps Computer spec is good Win XP SP3, 2GB RAM, 1.7Ghz Centrino processor and 250GB harddrive.
__________________
If I Knew then what I know now I probably would have written the code a little different! |
#2 |
Are you sure it's not just too many sections opened? When online all opened sections are being updated even if they're not visible on screen...
#3 |
The US company that was originally contracted to write CX-Programmer has been out of businees for quite some time. What geniuses write the code now, hard to say...
__________________
Don't trust, don't fear, don't beg... |
#4 |
it is the USB converter.
i have same problem when using USB converter but zero issues when using built in RS232 port |
#5 |
There was an issue which is resolved by the online update system.
Run the autoupdate, and you're good to go. Pp
__________________
Whatever hits the fan will not be evenly distributed. |
#6 |
Also set CX-P to go online @ 155k - it is much better than 19.2k.
__________________
The Old Pfhaart ![]() |
#7 |
Hi, all fixed - Auto Update sorted things out.
was running CX Programmer version 8.01 and CX Server ?.? (July 2008) now running CX Programmer version 8.20 and CX Server 4.3 (2009) Have also set baud rate higher (19200 max) but didn’t notice to much difference will probably revert to default (9600)to avoid future issues getting online. Thanks for your feedback.
__________________
#8 |
I made a boo boo before suggesting 155k - it should be 115k baud. I run serially at 115k baud all the time these days - never slower with the modern PLCs - never have a problem. I use the Omron USB/serial converter - it is not cheap but works without a hitch always.
Even run at 115k baud with the Promi bluetooth serial ports.
__________________
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
CX programmer communication glitch? | mordred | LIVE PLC Questions And Answers | 8 | May 14th, 2007 10:50 AM |
Instruction Equivalents of Omron Cx Programmer to GE Fanuc PLC Developer | SriGR | LIVE PLC Questions And Answers | 1 | January 11th, 2007 07:36 AM |
Omron CX programmer software | astahl-cc | LIVE PLC Questions And Answers | 2 | July 17th, 2006 05:10 PM |
S7 - Slow screen updates in ProTool | RMA | LIVE PLC Questions And Answers | 0 | August 2nd, 2005 08:11 AM |
how often should I trigger the PID? | Ron Beaufort | LIVE PLC Questions And Answers | 11 | February 22nd, 2003 12:57 PM |
