Omron cx programmer DIFU and DIFD, one-shot instruction
kokomel
Jun 2011
australia
The code of Emergency switch is following, when you press the switch the machine stop.
In ControlFunctions :
DIFU and DIFD is same variable : ipb_emergency_stop_sw, BOOL data type
on Set/input rung of a KEEP instruction(variable :gpb_emergency_stop,BOOL)
---------DIFD------------------------gpb_emergency_stop
on Reset rung
---------DIFU------------------------gpb_emergency_stop
In Process :
DIFD now is gpb_emergency_stop
on Set/input rung of Keep instruction(variable: sta_power_on,BOOL)
---------DIFD------------------------sta_power_on
can anyone explain DIFU and DIFD in here, anything to do with scan cycle ? why DIFD is placed on Set rung of sta_power_on Keep instruction not on Reset rung ?
Of course the actual cutoff of power should take place outside the PLC. But a STOP wired function should be wired such that it takes place when an input turns OFF. This is to take into account a possibility that the wiring from the STOP device becomes disconnected.
Therefore the turn off (DIFD) actuates the 'emergency stop' function (whether this happens because the stop device is indeed actuated or the wiring is somehow disconnected.)
Only if the input turns on, implying a proper release of a properly wired actuating device, is the 'emergency stop' removed.
Thank for answering, but you are a bit off the track, my theory is Set rung is supposed to turns on bit sta_power_on and Reset rung turns off the bit or shows what is the next state. Why DIFD is placed on Set rung why it should have been on Reset rung. If possible can you talk more about scan cycle, i mean the one-cycle of one-shot instruction, i dont understand it here, I appreciate.
Thank for answering, but you are a bit off the track, my theory is Set rung is supposed to turns on bit sta_power_on and Reset rung turns off the bit or shows what is the next state. Why DIFD is placed on Set-rung,it should have been on Reset-rung. If possible can you talk more about scan cycle, i mean the one-cycle of one-shot instruction, i dont understand it here, I appreciate.
Hi I'm new to Omrons CX Programmer (although not new to PLC's in general) and I'm trying to implement a one-shot with the DIFU instruction...
15,418
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
316
I am using a function block that has a in/out parameter that is a structure. The structure has an array as one of the elements. I can index the...
706
Is there a way in CX-Programmer to call Ladder Instructions from a structured text program? I can see several functions in the autocomplete...
1,850
Is there a way in CX-Programmer to call functions from a structured text program? I have found this manual that seems to describe the process...
1,006
