BradSensenig
I am currently converting a SLC 150 program to a RSLogix 500 program (MicroLogix 1400). In the SLC 150 program there is a timer (901) that has 16 RST instructions tied to the same timer. Under each RST instruction there is RE and then a value. The RE valve is different for each RST instruction. I am not sure what the RE means and how it effects the timer.
I have attached a copy of the program. I am specifically looking at Rung 017 (where the timer instruction is located), and Rungs 019 - 033 (where the RST instructions are located).
I understand that an RTO instruction needs the RST instruction to reset the RTO. I'm wondering why there is 16 RST instructions for the same timer and what the RE is so I can convert accordingly.
Thanks in Advance.
Thanks in Advance.
