Can't get PIDE to use Controller Scoped tags in version 30
lunenburger
Jul 2008
Summerside
207
Has anyone had an issue adding a PIDE instruction to a Function Block sheet in Studio Version 30?
I have created a controller scoped PID_ENHANCED tag and then added a PIDE to my function block page, usually in earlier versions of Studio I could copy the controller scoped tag into the tag tab of the PIDE instruction and it would use the controller scoped tags.
Now in version 30 when i copy the controller scoped tag in, it automatically creates a new program scoped tag.
This is difficult to access with Factorytalk view.....
It automatically creates a new local tag for it but you can swap it out for a global scoped tag by using the drop down at the block tag name.
Also to access program scoped tags from FTV
use the {::[topic]Program:programName.Tag} syntax
I didn't realize how easy it was to access the program tags from Factorytalk.
I checked with tech support and they said it was best to keep the program tags when using PID instructions in function blocks and not use controller tags...
Dear All Trying to get a PIDE controller to give output but cannot see our error. Is there a document that clearly states which input s need...
2,360
Greetings ... someone sent me a request for some student handsouts that I developed ... turns out that I had this hosted on my business website...
128
Have a logix controller and I'm using the PIDE block for the autotuner. I've got the hang of doing it for direct control things like pressure...
21
1,758
Studio 5000 version 34. Have error on PIDE CVFaulted (Status1.2), Control variable (CV) health bad. No more information online or in...
965
Hi everyone, I am trying to add a control loop to my HMI interface however I keep getting the following issue, any idea why this would happen?
1,611
