In addition, some of the bits in the M tables are system bits. Things like ALWAYS_ON, ALWAYS_OFF and first scan bits. You need to check the Mitsubishi documentation.
As posted above, the system bits (depending on the PLC Model) are M8000 > for FX, SM0-xxx for the Q series, although I believe there is some cross over, M bits 9000 > are used for the GXIEC/GXWorks as temporary or local variables at compile time.
