ceilingwalker
Thanks Paul!, I sell a LOT of these... it has a short PM02 and CP3 with our USB to RS232 https://www.plccable.com/usb-allen-bradley-1747-cp3-1761-cbl-pm02-plc-programming-cable-kit/
Yes if you have a Keyspan and a serial CP3 or null modem it will work just fine, connect to the DB9 port and use the DF1 driver in RSLinx, select the correct COM port and click auto config, it should say Successful! if it does go to RS Who and right click on the compact and there you should be able to configure the Ethernet port
5 years later when you need to do it again just search here (if it works)
Isn't that the truth! This is why I despise AB serial connections, it never connects right away, it takes multiple trips to the forum. Lol It displays "Port Conflict" in RSLinx yet, there's nothing else connected to the laptop. I disabled then enabled the Keyspan but it's of no use.
