alive15
Good afternoon, I am new to programming the PanelView series from AB and need some help with getting my tags to work on the HMI created by OEM.
I have added about 5 tags to my Studio logix 5000 v32 program. Then, I created numeric display* and tied these numeric displays* to those 5 tags by manually typing in the tag name into the "value" box in connection tab and left the polarity blank. After creating the runtime app, I downloaded into the HMI. I can see the numeric display box, but can't see the numbers from my PLC.
Also, another issue I'm having is I can't find a list of all the other tags being used on the HMI? When I double click any buttons that the OEM created, I can see the tag they used. So when I type in my tag in the same format for my numeric display, it did not show up with the value (I see 4 asteriks instead of my 4 numbers). If there is a database I can just open up and view all available tags so I can select one, that would be helpful as well. I thought clicking the 3 dots below "tag" in connections tab would load it up, but I only see two folders: one for the PLC, the other for system. The PLC folder is empty???
Any help appreciated, thanks.
*Edit
*Edit
