Catalog Update - GSD file for Mass Flow Meter at Step 7`
misamark
Oct 2006
Malta
55
Dears,
I need to add Siemens SITRANS FC430 to the existing PROFIBUS on the machine.
I have downloaded GSD files, but while trying to update catalog to add, I got the message "An Update is presently not possible. In one or more STEP 7 applications at least one GSD file or type file is being referenced"
I have opened another PLC program and easily updated with GSD files, but SITRANS flow meters does not appear in the catalog, cannot add to the PROFIBUS network.
Any idea what I am doing wrong?
Thanks in advance!!!
Hi SigmaDelta,
GSD files installed successfully, but these do not appear in the catalog. I cannot add it to my Profibus network. Simply, there are no SITRANS flowmeters to add. Seems that Step 7 v5.5 cannot accept these devices.
Any suggestion? Maybe I am doing something wrong...
Thanks in advance!
After you install your GSD, you have to chose Update Catalogue from the same menu, then your new device should appear in the HW Catalogue.
Tried already... Does not appear.
Something with compatibility I think, with Step7 V5.5.
Can you please try to add to your STEP 7, and see will it appear?
I am sending you GSD files to try.
Hello, I am quite new to use this enviroment for programming PLC and I have big problems to find out, how to download hardware updates in this...
18,179
I'm Confused. I have S7 V5.4+SP5 Installed. When i Compile my project i get the message i have 6ES7 151-8BA01-0AB0 (CPU IM151-8) online, but...
2,778
Hi, I am using step 7 v5.4 SP2. My available cpu is 6ES7 414 4HJ04 0AB0 V 4.0.9 but in hardware catalog v 4.0 is available. therefore in...
23,939
Hello, I would like to use a ET200S module but it is not yet listed in my catalog (current modules version 08.2005). Is it possible to install a...
6,908
Hello. I am struggling with this and it seems it is in from of my eyes but I still don't get it. In Logix 5000 catalog I have registered the...
1,552
