Ascii module programming
Oct 2020
Michigan
Hello everybody. I am currently trying to send ZPL commands to a Zebra zt410 from a compactlogix L30ER with v30 studio 5000. I am connected to the printer via a 1769 ascii module channel 0. I have already saved a format to the printer and I am able to print from the command prompt in zebra setup utilities using ^XA ^XFR:xxxx.ZPL^XS ^XFxxxxx^XS^XZ. I have entered each character into the sint tags that are created in the tag database under local:3:O.TxData and I have switched the style to ascii from decimal and all my characters check out. I have entered the correct length in TxDataLength tag. I haven't written any code yet I am just testing by changing the value in local:3:O.Ch0TxID. The printer does nothing. The status indicator for Tx0 does nothing and the input tag for TxDataSent is still 0. Any help is greatly appreciated.
PS. I am in the process of acquiring the network connect and special firmware to do this via ethernet but I thought I would try serial in the meantime.
This is maddening. I'm developing a new application where a 1769-L32E with a 1769-ASCII module is communicating with a Tegam micro-ohmmeter...
1,581
Does anyone know how to inhibit the 232 module from sending data during PLC power-up? To send data during normal operation, the Transmit Record...
1,903
Hi All, I have IM 151-7 CPU [6ES7 151-7AA13-0AB0] with ASCII Module [6ES7 138-4DF01-0AB0] and EPSON [LX 310]. Printer is connected with ASCII...
1,593
Hello Everyone, I am looking for some help on this dreaded 1769-Ascii module. I have been doing a lot of digging on this module in the forum...
2,432
I have a current source and I want to control the output state, the voltage setpoint and the current setpoint. Also I have to monitor the current...
2,496
