Time Stamps to Calculate Duration in Machine Expert
Sham
Sep 2019
Australia
152
Hi All,
I have a rather simple task, but have no experience with the Timedate library so posting here. How can I calculate the time duration between two events ? for example, have to calculate the time duration of a motor running, by calculation the time duration between the time I press the Start button till I press the Stop button.
So, its like time_elapsed = TimeStop - TimeStart;
I'm also new and this is what I think should work:
Configure hardware events for each input, rising or falling.
Add two tasks and assign one for each event and program call in each task.
In each of the programs called by the tasks get system time.
In the cyclic program somewhere calculate the time difference.
Add SysTimeCore library to get the three functioins:
SusTimeGetms, SysTimeGetNs and SysTimeGetUs
Edit : I should add that I haven't tried it yet.
Have a look at the .gif in this link
Thanks Kalabdel, I had similar thoughts. I wrote this:
--- --- --- VARIABLE DEFINITION --- --- ---
FUNCTION_BLOCK TimeDuration
VAR_INPUT
START: BOOL;
STOP: BOOL;
END_VAR
VAR_OUTPUT
OUTPUT:BOOL;
END_VAR
VAR
Trig_Start:R_Trig;
Trig_Stop:R_Trig;
stUnixStamp:SysTimeRtc.SysTimeCore.SYSTIME;
stdate: SysTimeRtc.RTS_SYSTIMEDATE;
Start_Stamp:ULINT;
Stop_Stamp:ULINT;
Time_ms: ULINT;
Runtime:ULINT;
END_VAR
--- --- --- LOGIC --- --- ---
Trig_Start(CLK:=START);
Trig_Stop(CLK:=STOP);
IF Trig_Start.Q THEN
OUTPUT:=TRUE;
Start_Stamp:=stUnixStamp;
END_IF
IF Trig_Stop.Q THEN
Stop_Stamp:=stUnixStamp;
Runtime:=(Stop_Stamp - Start_Stamp);
END_IF
This looks logically correct, but somehow is not giving any results.
The code I suggested is supposed to have nanosecond precision and not tied to scan time; it is based on generating hardware interrupts (trigger events) for digital inputs and using system function that retruns time in nanoseconds.
In most of my project I need to display time counters in the HMI. So I have created a library of different hour, minutes and seconds counters/timers.
The following FB is simple time counter that outputs the time in hours, minutes and seconds that has passed since xEnable was set high.
Code:
FUNCTION_BLOCK PUBLIC FB_TimeCount
VAR_INPUT
	xEnable:BOOL;
END_VAR
VAR_OUTPUT
	uiElapsedHour:UINT:=0;
	uiElapsedMin:UINT:=0;
	uiElapsedSec:UINT:=0;
END_VAR
VAR
	uiElapsedTime:UINT:=0;
	udNowTime : UDINT;
	udPrevTime : UDINT;
END_VAR
Code:
udNowTime := TIME_TO_UDINT(TIME());
IF xEnable THEN
	IF (udNowTime - udPrevTime > 1000) THEN
		uiElapsedTime := uiElapsedTime + 1;
		uiElapsedSec := uiElapsedTime MOD 60;
		uiElapsedMin := uiElapsedTime/60 MOD 60;
		uiElapsedHour := uiElapsedTime/3600 MOD 3600;
		udPrevTime := udNowTime;
	END_IF;
ELSE
	uiElapsedSec := 0;
	uiElapsedMin := 0;
	uiElapsedHour := 0;
	uiElapsedTime := 0;
END_IF;
Code:
VAR_INPUT
	xEnable:BOOL;
END_VAR
VAR_OUTPUT
END_VAR
VAR
	udNowTime : UDINT;
	udPrevTime : UDINT;
END_VAR
Code:
IF xEnable THEN
	END_IF;
ELSE
	uiElapsedSec := 0;
	uiElapsedMin := 0;
	uiElapsedHour := 0;
	uiElapsedTime := 0;
END_IF;
Thanks Kalileo, please check your inbox!
It looks like the SysTimeRtcHighResGet function is not supported in all CPUs, definitely not my M241.
Thanks Kallileo. I can add the library and have access to the instruciton; I do not get any errors it just doesn't output the result.
You are right though, it is supported in M241 I will spend some time later to get it to work.
Almost every piece of code I write in ST is a state machine.
The following code counts motor operating hours add them to the old values values that can should be declared as Persistent variables in SoMachine/Machine Expert/Codesys.
You can also convert the operating minutes to hours and add them as well.
Code:
VAR_INPUT
	xEnable:BOOL;
END_VAR
VAR_OUTPUT
END_VAR
VAR
	udNowTime : UDINT;
	udPrevTime : UDINT;
	iStatus : INT :=0;
END_VAR
IF xEnable THEN
	CASE iStatus OF
	0:
		uiElapsedSec := 0;
		uiElapsedMin := 0;
		uiElapsedHour := 0;
		uiElapsedTime := 0;
		iStatus := 10;
	10:
		END_IF;
	END_CASE
ELSE
		iStatus := 0;
END_IF;
Code:
PROGRAM PLC_PRG
VAR
	motorOperHours : FB_TimeCount;
	uiOperHours : UINT;
	uiOperMinutes : UINT;
	uiOperSecs : UINT;
	xMotorStart : BOOL;
	ftMotor : F_TRIG;
	uiOldMotorHours : UINT := 10;
END_VAR
motorOperHours(xEnable:=xMotorStart, uiElapsedHour=>uiOperHours, uiElapsedMin=>uiOperMinutes, uiElapsedSec=>uiOperSecs);
ftMotor(CLK:=xMotorStart);
IF ftMotor.Q THEN
	uiOldMotorHours := uiOldMotorHours + uiOperHours;
END_IF
Thanks kallileo. I'm sure your code will come in handy.
I think you need to call the function to actually access the time.
Result := SysTimeRtcHighResGet (pTimeStamp := StartTime);
That worked for me.
Thanks for asking the question, it was a nice exercise.
Is it possible to calculate the time difference between two timestamps in Redlion crimson 3.1? Thank you,
1,407
Hi, I'm fairly sure that the boffins in here have already solved this several times but I cant find it... I have a program from an S7-400 that...
1,868
Hi guys, Thought I might ask here if anyone knows, currently have tech support looking for a solution. I have a micro820 and wanting to...
2,554
Hi All, Is it possible to alter the project date/timestamps for concept 2.6 projects? I have a remote PLC that I need to connect to but the...
2,421
Hi, i recently asked the question on how to unprotect s7 blocks, i got the answer and have done exactly that. i made a copy of the entire project...
4,711
