AD Productivity Suite Software now has a PLC simulator!
@Elcan:
Lo que pasa es que estaba buscando un simulador como software independiente, no pense que estubiera embebido dentro del paquete principal.
I was looking for an independent simulator software, but i see that it is embeded into main software package.
De todas maneras gracias, le voy a hechar una mirada.
thanks anyway
saludos,
william
For some of the limitations/restrictions of the simulator, look in the help.
Search (in the upper right search box -- NOT in the ToC/Index bar on the left.) for 'simulator' it will show as PLC Simulator with a .CHM link to308.htm.
As yet, the help-file search results are not quite correct. AD has stated that this is on the list to be fixed.
https://community.automationdirect.com/s/question/0D53u00002O76vkCAB/pac-simulator
Garry and I have posted that we have had success in preliminary testing of the simulator.
I tested it yesterday, and the first session quit, requiring a restart, but it was flawless on the 2nd try (Thanks to Windows, I'm pretty sure).
It makes a strong case for using an IO alias task, which can be drug to the Disabled section for simulation, since I had not re-labeled the IO. Since I have an HSC in the setup, I don't believe it would simulate properly anyway (Help/Release says no Intelligent Modules).
I wish I could use the C-More with it. Using the C-More Simulator would be even slicker!
My reason for wanting it is that I have a project in the field which I am still building 'Features' for. I have a CPU and C-More here, but without all the IO on the CPU here, it faults out unless I change the hardware configuration. So, I had 2 programs, and drug tasks between them as I finished them. This is klutzy, and things can get lost/misplaced. But, since I can't use the C-More with the simulator, I'll still have to do this, just not as often.
I did a simple CMORE to PAC-SIMULATOR. I targeted the CMORE project to the PC's IP Address. Setup tags, the comms worked.
I am not trying to say that this will work in any/all cases, but it DID for a simple 2-boolean test.
[EDIT: clarification. I did NOT do a CMORE Simulator to PAC simulator. CMORE Hardware to PAC simulator]
Update: Yes, the C-More is working, using the PC's IP Address rather than the PLC's.
Also, I can only assume there's a run-time limit on the simulator, as it quit again, requiring a restart of the program.
OK, 2 hours seems about right. I had it happen a few more times, but it was longer than 1 hour...
I hate AD's new forum. They took a huge step backwards IMO. I don't check in there as often now.
Yeah several of us have told them so... Sadly, to no avail.
I do not participate as much or from as many locations as I once did.
Hello everyone, I am just starting to use productivity 2000/3000 and got some questions: 1) How could I get the modbus address of a tag if I dont...
2,328
Looking at the compare values instruction, it seems as though you have to use 2 separate boolean tags to perform a greater than or equal to...
1,158
For example, I need to set 1011-0011-1100-0011 into a memory location. I am trying to look for MOV function in Productivity Suite. However, I...
1,287
I think this is great news! After many years waiting for it, I'm happy we have User Defined Structures for the Productivity PLCs. For those not...
18
6,776
i have an instance where a limit switch activates a solenoid. My issue is that my on timer only works so long as the limit switch is held down, or...
3,062
