1756-IF16 0-10V Only Reading 0-2.5V
rjj11
Oct 2020
Brisbane
Hi all,
As stated in the title, I have a 1756-IF16 module that was previously only running 4-20mA current inputs. I am now adding in 3 0-10V voltage inputs, and have configured them as such in Rslogix 5000 v19.11. We are simulating a 0-10V input using a process meter which is working fine, but once we inject 0-10V into the card it only reads 2.5V max (we also had a meter on the terminal we were injecting and it was reading 0-2.5V when the channel was connected & 0-10V when it wasn't).
Does anyone have a solution for this? All the returns are currently bridged with a jumper but from what I've read that is required regardless of if we use voltage or current.
356
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
145
Hi Guys, Hoping that someone could please confirm if the 1756-IF16/B is/isn't compatible with the 1756-L1 5550 processor(13.24). I'm sure I...
103
Hello, friends my 1756-if16 differential connection, has been used again (almost 10 years), the measurement value of each channel of the entire...
971
I have an existing 1756-IF16 wired as single ended with all RTNs tied together. Channels 0-3 have 2-wire loop powered devices connected with all...
1,067
