Serial communication between Compactlogix L19ER & Micro850
Dec 2013
New Damietta city
34
Hi Experts.
I need your help, I wanna communicate a MIcro850 with L19ER CompactLogix
through Serial communication (Modbus RTU).
I am using ILX34-MBS485 for compactlogix in order to make the communication with micro850
Note : the distance between the 2 CPUs more than 100 meter.
Any idea or useful papers in this case
Firejo said:
Why not use Ethernet?...
mahmoud shahien said:
...Note : the distance between the 2 CPUs more than 100 meter...
I think our friend is investigating other options due to the age old distance limitation of 100 meters for Ethernet copper media.
Ethernet is still an option here but to connect these two greater than 100 meters apart controllers together using Ethernet would require intermediate appliances which facilitate long distance interlinking, such as fibre media between two switches...
50865 - Connecting two Allen-Bradley Controllers, 100-2000 meters apart, over Ethernet
Access Level: TechConnect
This may or may not be a suitable option for this particular application, but still, I'd like those not sure in general to be aware of this normal practice of using fibre media to bridge longer distances while using Ethernet based protocols.
Regards,
George
I am working to control some objects using Weintek HMI through Fatek PLC. I wrote a simple program to control an output Y_0 using input X_0. I...
3,811
problem in communication between micrologix 1200 & Panel View 600 Plus by serial DF1 Hello Friends i have to do communication between micrologix...
6,610
Hello everyone, I want to make a serial communication using Siemens S7-1200 with CM 1241 (RS-232) and communicate with my Arduino. Here is the...
9,775
Hello. I want to establish serial communication between the S7-300 and a raspberry pi. Toward that end, I'd like to begin by sending a simple 1 or...
7,290
Hi everyone, I'm trying to go online with an IFM PLC over a serial connection, using CoDeSys. Things were working fine for a while; I managed to...
11,443
