PLC AB model Slc 150 user manual?
Platootod
Jan 2003
Mechatronics RIT.Non
215
I have met 2 machines from Canada .Friction material mixers use
plc AB model SLC 150 (quite old).
Where can I find the user manual in this PLC model?
Information about hand held programming SLC 1745 -PT1
How to read ,write program by hand held?
Thank you very much for your's kind help in advance.
Platootod
I have renew program by hand held...
Dear Sir,
I have renew program by hand held 1745 for SLC 150 ,yes
the machine work complete again.
However, the problem is occur again after sometime ..plc show
error code6 = processor memory error.
Do you have any idia for this , should we replace battery back up?
Need eprom to save program?
Where can I buy the cable to connect plc with computer?
Thank you very much for all kind help. ;)
Platootod
How about a quick search here?
The old "how to make a cable/convertor for a SLC100/150" topic is quite common here.
There is a thread discussing this right now. Here is a link.
Litium battery
First ,,many thanks for all kind help answer.
Do you have any idia with litium battery?
My opinion , May be this is a chepest way to keep user program of these machine.
Now,I trained the technician there for key and re write program to those machine ,but take time.
If anybody has experience in SLC 150 and battery backup ..
I appreciate all answer.
Thank you very much.
Platootod
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
108
Has anyone ever heard of this model PLC? It looks like a PLC-2, but I'm wondering if it the programming and communications are the same.
1,111
Hello everyone I have Panasonic plc ,the problem I am facing the error led is blinking continuously,but machine is working properly after sometime...
1,642
I have been doing this project as a means to learn PLC programming. Awhile back I got stuck in a rut with doing this project and I asked some...
2,184
Thought I'd post this to help other's out :) Any further questions, don't hesitate to ask. Credit to Keithkyll for his advice!, Using 24v power...
2,021
