1794 Flex I/O Error: Mod Config Reject
Mfleming
Jan 2009
KY
17
Hello. We have an issue on one of our machines using Flex I/O. All of the flex I/O are faulted on one chassis (7 I/O cards total). The cards are all digital I/O's (Part# 1794 IV 16/A and 1794 OB 16/A). The error code is Code 16#0118 : Module Cofiguration Rejected: Format error.
This machine has been in service for over a year now and the I/O config has not been touched. I tried to disable keying and had no results. I also tried to turn off rack optimization and also had no result. I swapped to another known active ethernet connection, still the same. Swapped the Flex adapter out and nothing.
I'm sure it is something simple that I'm overlooking. I don't have enough spare parts to swap all the cards and cross my fingers. Any suggestions on how to diagnose this one?
I reduced the chassis to 1 and now have the fault Code 16#0204. I checked connections and it appears to have a good connection.
Disregard the last post, typo on the IP address. I was able to clear the fault with the adapter card disconnected from the backplane only. I am getting a backplane module ordered right now.
Thanks I'll post my findings.
Hi all, what is the proper way to fuse 1794-IE12 modules? fuse sizes/locations? We are burning up these modules in our facility.
1,721
Does anyone have any insite to when the 1794 Flex io will go active mature? Just not ready to switch to the new flex 5000. We use flex for remote...
1,605
Hey guys, Im currently using the above flex IO to turn on two outputs these outputs go to two flashing red beacon lights. Here's the scenario: My...
1,706
Anybody can help me. I already read document in software rslogix 5000 and I think i can use software rslogix 5000 calibrate for flex module...
1,735
This is going to be long winded just because i am going to try and provide as much info as possible. Over the last month i have had the...
2,405
