Converting .RSS file to Click (.ckp) - Timer status bit equivalents
rguimond
Jul 2009
Escuminac
665
I've finally gotten around to programming an AD Click PLC that's been sitting in my office for close to two years. The main reason I'm using it is that the ML1100 I was planning on using for this project won't fit in the available space.
Converting rungs with inputs, outputs and internal bits has been a breeze, but I'm hung up on what the equivalent bits for timers status (.EN, .TT, .DN, etc.) are. I've gotten around TT by using a Greater-Than contact that I use to compare TD1's current value to "zero". If the contact is true and the conditions that started TD1 are true, the timer must be running.
For an equivalent to DN, I compare current value to SetPoint.
I'm sure the above work-arounds will work fine, but I'm guessing there's a much more elegant way to make it work.
BTW, the .RSS program I'm converting only has a dozen rungs and is for a floor scrubber. My intention is to broaden my experience by converting this on my own, but a little push in the right direction would go a long way!
Timer done should be the done contact associated with the timer. It is shown to the right of the timer box. For T1 it would be T1 as a contact.
For TT all you really need to do is TD1>0.
For EN it should be the same condition set that enabled the timer.
I do it with extra C bits. I parallel from the enable line into the timer to a C bit as the 'EN' equivalent. Continuing down from that enable line I place a NOT of the timer contact ending in a C bit as the 'TT' equivalent.
Of course you don't have to do both, just what you need. Just for clarity pre-gather all the enable conditions (X1 in this example) into a single bit. Then the timer rungs can all have the same general appearance.
Hello PLCs Forum, I am in a bit of a pickle and was hoping someone could offer me some help. I have a .rss file and just need to see the ladder...
95
Hi, I tried to do it, I used "Traslate PLC-5/SLC 2.0" but i don´t know why it didn't work. the program get stuck in the step four "Processor...
2,305
Evening, Is it possible for anyone to convert my .RSS File to a PDF as I don't have the software available. Many Thanks!
2,395
Hi everyone... I'm trying to find a free converter online but without success. I want to convert an .rss file to pdf so i can review it on my home...
2,672
Hi Can someone please convert these into PDF, I don't have the full version. Cheers
1,372
