Old Screen Creator Software for DP-C321
Problem solved. Brainfart. Too many old programs in my collection and while transferring from 1 computer to other, mixed up what I thought I was doing. If I knew how to delete the previous post, that would be best as most of what I typed is wrong.
Lets leave it up... thats how we learn as a group (y)
By the way AtoZ, welcome to the club and glad you found your issues, thanks for coming back and letting us know! :site:
Screen Creator will not run on this PC
I obtained a download link directly from AutomationDirect for Screen Creator v117.
Unfortunately, when I attempt to install it, I get a "this app can't run on your PC" error. I made sure to "unblock" the downloaded ZIP. I have tried every compatibility mode from Windows XP SP3 to Windows 7 with no success. I tried on two separate Windows 10 computers. Any idea why I cannot get this to work????
Did you download it from https://support.automationdirect.com/products/sc.html
Because if you did it says on that page:
Do not delete any existing ScreenCreator files!! This is a maintenance release, not a full install. You must have a previous version of ScreenCreator to install this upgrade.
Also from reading the first couple of pages from the ScreenCreator user manual it seems to run under either W95/W98 or NT
Did you unzip the package to a folder before you tried to install it?
I downloaded the installer zip file from a link I received from a technician at AutomationDirect, which should be the full installer.
I did extract the ZIP file to a folder on my local hard drive before attempting to install.
Ozpeter is correct, the link you downloaded from in not the full package.
The software you need is from a protected area. Send me a PM and I will give you the correct link and password.
Andy
This is the same link I was given by technical support. I downloaded it again and have the same problem. Version 1.17 is a maintenance release. Apparently I need v1.0 which is not available, even from the restricted area of the download site.
I have asked the technician at AutomationDirect to please have someone check the company's software repository for the last full version.
We did purchase the software almost twenty years ago but even if we could find the diskettes, they would probably not be readable.
Need Screen Creator for DP-M320
Hello,
I realize that this is an old thread and that the HMI that I have is even older. However, I was hoping someone would be able to and kind enough to give me the install files for the old Screen Creator Software. I am trying to salvage a project from an old DP-M320 to another DP-M320. I would greatly appreciate any help/information you guys can give me.
Thanks,
Tyler
Just wondering if anyone out there knows what to do with a .tss and .tsr file. I have a customer with an old screen we are replacing and found...
1,400
I have a customer with a few machines that have OLD Proface GP37W touchscreens with one dead. They have a couple GP37W2's off similar machines...
3,180
Does anyone know what the com port pinouts are on this monitor? I can't seem to find any information as it is discontinued. Thanks
1,972
Hi everybody i have an OMRON NT20S-ST121 touch screen and NT support sofeware which is 4.6 version. but i can not communicate with the touch...
3,357
Hi All, I would like to know hoe to import the symbols edited in excel into SLC or Panelview. Thanks.
1,960
