Communication... Automation Direct DL405
geniusintraining
Jun 2005
SC
8,268
Hello,
A customer is having me look at a few upgrades to their systems, they are also having a hard time getting support for the equipment from the OEM (busy??), so today they asked me to uploaded and back up everything, so today I uploaded several programs, Automation Direct, AB and Hitachi
All of the Allen Bradley's went very good, all of the Automation Direct went well but one, they had several 205's and one DL405 D4-430 CPU I could not connect with it, it had a 15pin on the top connector and a 25? on the bottom, they had a S2-15p connector/adapter on hand so I tried to use it but no luck, I was using the D2-DSCBL that I used on the 205's, I thought that S2 adapter would allow me to connect to the 405???
Or do I need the D4-DSCBL
Mark
The Hitachi is a different thread :) it took forever just to find a port :( and I still don't know if its the correct one
I'm pretty sure offhand that the S2 adapter should work with the D2-DSCBL. The keyswitch should be in "Term" mode, 9600, 8 bits, 1 stop, Odd Parity, K Sequence Protocol.
DirectNet protocol won't work on Port 0 of the D4-430.
Thank You!
I tried to get it to configure with the 'auto' using the S2 but no luck
I ordered both cables (upper and lower port) for the DL405 last night, then I figured I could not go wrong :).... well I hope
You guys are fast on shipping, so I will have them tomorrow and give them a try... thanks again
Mark
Hi all I have micro logix 1200 and automation direct panel (EA9-T6CL). I have downloaded .RSS file in micrologix 1200 using 1761-CBL-PM02...
1,795
Dear All if any body can help me in establishing communication B/w WAGO RS232 module and automation direct My Controller is 750-841 and...
6,625
I am working on a Lookout direct scada communicating to a DL06 PLC through wireless Ethernet.The problem I am facing is, intermittent loss of...
7,171
Looking for any advice out there in regards to a communication strategy between Visual Studio 2013 C# windows application and either an HMI...
4,976
Hi, I am having a EZPLC and ASCII device, I need to communicate with my EZPLC with that device. Firstly i need to send a command ~5 1 to the the...
3,101
