Upgrading to Windows 7 Professional for WinnCC software
Timeismoney08
Jul 2012
United States
312
Does anyone know of a easy (cheap) way of installing windows 7 Professional, Enterprise, or Ultimate?
I need it to install my WinnCC software.
Or do you know a way to trick WinnCC into letting me install it anyways?
I know with Step 7, it wouldn't let me install it, it popped up and said you have to have windows Pro, Enterprise, or Ultimate. I kept pressing "X" out of frustration, and it started the install after a dozen presses.
What about the possibility of a Virtual Machine?
It may be a little more work to get it going but if a cheap soloution is what you are looking for...
You can probably download an older version of workstation somewhere on the internet.
I don't know about using the XP Mode on your windows 7 environment. I am not sure weather or not it will still act as if you are running WIN7 HOME. Worth a try?
Ahhh. I see
I guess you could do what I did , go to Best Buy and buy it
What other recourse is there?
Yea, that's no fun. Might end up becoming my solution though.
Maybe, but I thought you still needed the install to use a VM.
Gotta have at least Win7 Pro to use XP Mode.
Alternatives are using VMWare Player or VirtualBox to host your XP install.
Note: I linked to v5 of VMWare Player. V6 has now gone to VMWare Player Plus-- which, from my reading, is still free, but has nags to try to get you to purchase.
EDIT: Forgot to mention, you'd still need a licensed copy of XP. Sorry 'bout that. But you can get new/sealed versions of XP on ebay. Some, like this one, give all proceeds to charity.
EDITED EDIT TO COVER PREVIOUS EDITS THAT I FORGOT TO EDIT: If you decide to go with Win7 Pro (something like $139, IIRC), then you get a complimentary XP license to use with XP Mode. Looks like you wouldn't need it for WinCC, but between the two (Win7 Pro and XP Mode), that should cover quite a bit of legacy stuff.
There are always tweaks and methods available in order to be able to run it. It's just not really supported...
Hi, I was wondering if you could get some advice. I current have a standalone iFix 32 SCADA System. We are running the iFix 7.0 (build 112) on a...
18
7,098
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
404
We are in the process of upgrading a controls system. The existing system is a SLC500 with some IO cards and a 1747-SDN module communicating to a...
539
I am looking to upgrade some of our old Servo Drives to the newer kinetix 5700 style. currently we have 4 1394 axis that are all driven by 5kw...
877
Hello, We are currently running a bunch of g310's connected to their SLC5 PLCs through ethernet. I've attempted to upgrade the program from 2.0...
1,121
