FactoryTalk Activation License for Rockwell Software
Dlareg
Jan 2014
Singapore
I am pretty new with FactoryTalk Activation so bear with me regarding this inquiry.
We have a new laptop and I was tasked to install the Rockwell Software on it (RSLogix5000, RSNetworkx for Controlnet,Devicenet,Ethernet and RSView). My other colleagues passed to me the installation CDs but all the product keys information were lost which are needed during the FactoryTalk License Activation process. Hence, I have requested from Rockwell TechSupport and they sent me a FactoryTalk License Certificate with a new serial number and product key for RSLogix 5000 (I have not activated it yet, currently in the field work).
The Factory Talk License Certificate they sent to me is just for RSLogix5000. My question is do I need to have separate FactoryTalk Licenses for the other software (RSNetworkx for Controlnet, Devicenet and Ethernet) and for FTView?
If you have the Serial Numbers and registration info for your other pieces of software, Rockwell Support should be able to send you new product key information sheets. Just call their tech support line and go to the Copy Protection and Factory Talk activation menu.
Dlareg said:
...do I need to have separate FactoryTalk Licenses for the other software (RSNetworkx for Controlnet, Devicenet and Ethernet) and for FTView?
Just to verify...
RSLogix5000 and FTView require one license each.
RSNetWorx for ControlNet, DeviceNet and Ethernet will also require one license each.
So that's five licenses in total.
George
The plant I work in uses Rockwell software primarily. We serve licenses to users with Factory Talk Activation Manager using a server running...
1,582
Hi All, We have a new laptop and we have successfully activated the Rockwell Software through FactoryTalk Activation. All the licenses are saved...
15,609
Hi Folks, who know why after start FactoryTalk activation manager V4.03, click "Get New Activations", it displays Is not I appreciate with any...
61
Rockwell Tech Support seemed to have hit a wall with this question. Already updated the version to 5.00.13 per their suggestio but am still...
217
Hello all, I have the misfortune of needing to support some old firmware version 1756 controllogix machines in rslogix 5000, as well as some...
954
