RSLinx Classic generates windows installer error 1722
JToman
Jan 2009
USA
Gents,
I have a RSLinx Classic V2.52 running on Windows XP. It worked great for several years, all of a sudden I started developing a problem, where if I try to launch an app. that uses RSLinx to go online or if I would click on the tree trying to view the network, I would start launching Windows Installer.
I thought that by removing the RSLinx and re-installing it again I would get rid of this fault, however the removel process failed half way through and I was getting Windows Installer error 1722. I have tried all I could to fix it but to no avail.
At this point RSLinx can't work because some of the files have been removed during the removal process and I cannot complete the removal process because Windows Installer errors out.
Does anyone have any ideas? Thank you in advance for your help.
Thanks for the link Ken. I did follow the instructions in the app. note and it did not help. Eventually used registry clean-up app. that fixed the issue.
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
182
Hey All, I am sorry to ask this, but i still gotta do it. What happens if I close RS linx? Will it cause network interruption and PLCs will lose...
154
Does anyone know if there is a way to import RSLinx Classic data into FT Linx? We have a quite extensive configuration set up, and it would be...
2,561
Hello, I entered my controller IP address as 192.168.1.100 (Local) for 1769-L33ER. It worked fine until couple month and found the controller kept...
1,134
Hi All, Looking for some clarity regards the relatively recent rebranding of RSLinx Classic. From what I can make out from the RA website and...
2,396
