OB81 and baf backup voltage failure on central rack
sultanahmed
Jul 2013
home
63
Hi Every one,
I am working on S7-300 PLC and CPU is 315 2 DP 315-2af03-0ab0/ v1.2.
Total number of racks 3 (1 CPU with IM360 and others are IM361 used).
I am getting error OB81 and baf backup voltage failure on central rack
when i dig the error which says
The 24-V voltage supply
A battery
The complete backup
I refer to CPU Input Power 24V which is ok check with multimeter, i check battery which is 3.3v .
CPU suddenly comes on SF and after some time, sf removes automatically.
when CPU goes on SF dim red light blinks on IM360 module,i replace IM360 module but still same problem, i replace plane connector of CPU same problem.
Some times it shows batt fault but some times dont.
this fault occurs frequently in a day.
I am confused what will be problem?
Please Advise
From your description it sounds like the processor itself. as you are getting a number of different faults and you have changed the connectors, the only other possibility is the Power supply. It definitely sounds like hardware problem.
A question
Does the 315-2DP CPU have a battery?Because you mentioned that you checked the battery & found it 3.3V
When performing a download on this PLC I get a message that OB81, OB84, OB101 and OB102 cannot be downloaded and do I wish to proceed? Any ides...
1,459
hello guys Im newly born baby in the world of PLC.I was studying the OB81 which is programmed for the battery indication.When i study the sample...
2,578
1,861
Is there a way to reset the count on the RS Logix BackUp?? XXXXX PROGRAM IN PROGRESS_BAK445.RSS XXXXX PROGRAM IN PROGRESS_BAK446.RSS XXXXX...
254
Please help me How to B&R 7CP476.60-1 upload program Backup and download which program should I use. Pvi transfer tool.? And how. Thank you
79
