plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Unread November 8th, 2019, 04:16 AM   #1
qwemx
India
qwemx is offline
qwemx's Avatar
Double acting Valve
I have double acting valve.
this need to be opened and closed .
now Valve remain open as long as power is connected to slenoid on power loss valve closes.
the solenoid is 4 way single coil
http://www.flowlinecontrols.com/sole...-valve-12.aspx
Is it possible to make it function in this manner give power to solenoid for few seconds and valve opens supply to solenoid is turned off and valve remains in OPEN
then next time when power is given to solenoid for few second it changes state open to close. this power also turns off after few seconds
Basically 3 second pulse for ON and 3 second Pulse for off .
Unread November 8th, 2019, 05:34 AM   #2
parky
United Kingdom
parky is offline
In a word NO, You really need a 5 port valve with two solenoids pulse one to turn on pulse solenoid 2 to turn it off, What it actually does is 5 ports pulse solenoid 1 to energize one way & exhaust other port, pulse solenoid 2 to reverse this. (note these are what you call stay put so do not need coil energized all the time). There may be pneumatic logic blocks out there that act as flip flops then you would need a slave valve to do the work.
Unread November 8th, 2019, 08:10 AM   #3
qwemx
India
qwemx is offline
qwemx's Avatar
Could you help me understand these arrows ?
it is reversing the flow of the air
Unread November 8th, 2019, 10:04 AM   #4
parky
United Kingdom
parky is offline
Have a look at this, It should give you the information you need, there are also pleny of sites with information on Pneumatic s.
https://tameson.co.uk/how-to-select-...-cylinder.html
Unread November 8th, 2019, 10:52 AM   #5
GaryS
United States
GaryS is offline
GaryS's Avatar
you can not do what you want with the valve you have it is spring return when power is removed
what you want is a 2 coil valve one coil to open and the other to close
your diagram is a standard cylinder control valve the arrows show the connected ports for the 2 states of the valve
port 1 is the incoming air supply
ports 3 and 5 are exhaust ports
ports 2 and 4 are to cylinder
any supplier should be able to get you what you need
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Double acting cylinder, single acting solenoid A+B+B-A- Copyleft LIVE PLC Questions And Answers 5 May 28th, 2018 03:25 AM
double acting vs single acting float switch Charbel LIVE PLC Questions And Answers 1 October 7th, 2015 09:17 AM
Double Solenoid Valve , three position valve? Tofo LIVE PLC Questions And Answers 9 October 29th, 2013 08:20 AM
diagnostics of a cylinder driven by a double solenoid valve Bartech LIVE PLC Questions And Answers 11 August 21st, 2012 08:40 AM
A double acting solenoid and a PLC Shohadawy LIVE PLC Questions And Answers 7 September 14th, 2008 02:42 PM
