FactoryTalk View SE - Button Issue
saeqsae
Jul 2019
Concepcion
45
Hi all, i'm trying to create a button with the option "Set tag to 1 on press and 0 on release" but i want to do the same with 5 tags and just one button.
It's possible? I tried writing "{Tag}AND{Tag}" and "{Tag}||{Tag} and doesn't work
Thank you in advanced
Change your button action to 'Run Command'
Press action
Code:
&Set {TAG1} 1;
&Set {TAG2} 1;
Release action
Code:
&Set {TAG1} 0;
&Set {TAG2} 0;
Might have to fiddle w/ the syntax, that is mostly from memory.
Hello, I'm quite new with using FactoryTalk View Studio. I am currently using FactoryTalk View Studio 13.00 and creating a runtime file for an...
959
Hi Guys, Please, how can I apply FactoryTalk View SE security code on a Button object? I tried 'CurrentUserhasCode' expression with Visibility...
2,251
Hello, I ran into an issue while editing a FactoryTalk View ME application. I have added two buttons to one of the displays and have used the...
3,108
Hello, I have an issue with the latest version of FTView Studio 12.00 where when I select the 3 dot button as is displayed in the photo...
4,108
I am working on someone else's HMI project and the HMI Shutdown Button is not visible in runtime. Even when logged in. When I look at the button...
4,309
