GE Fanuc 90-70 Programming port communication
sranjeit
May 2016
Barmer
Is it required to use Rs-485 to Rs-232 convertor to connect ME or OPC server to GE fanuc PLCs programming port ( 15 pin, RS-485) ?
Is it possible to communicate to PLC on 15 pin programming port using MOXA's RS-485 to Ethernet converter ?
Regards,
Ranjit Singh
1.Is it required to use Rs-485 to Rs-232 convertor to connect ME or OPC server to GE fanuc PLCs programming port ( 15 pin, RS-485) ?
2. Is it possible to communicate to PLC on 15 pin programming port using MOXA's RS-485 to Ethernet converter ?
Regards,
Ranjit Singh
1. Only if the ME or OPC end has an RS-232 port.
2. Maybe, you should verify with MOXA that it is compatible with the GE SNP protocol, specifically what happens if the MOXA sees a "Break" command which is what typically is used to 'wake up' an SNP communication.
Our PLC output 7 opens a valve to move a cylinder rod. The output turns on every minute. The output is supposed to be ON for 10.56 seconds. But...
2,872
Hey Guys, I have plenty of experience with AB plcs . What is a good starting point to learn about fanuc robot programming. How to get started? Is...
2,704
Good afternoon all, hope everyone is doing well. Could someone explain the pic attached on the wrt.not instruction? To me, it looks the same as...
2,107
Hello Everyone, I would like to get some advice from seniors!! Currently, I involve in writing PLC logic and Robot programs (ABB rapid...
3,879
Hi Guys, I'm looking for someone who might still have software that can open a program from and old 90-30 PLC. We have just taken on a new...
34
23,080
