GE Fanuc 90/30 Software Version
chrisgreg
Oct 2017
Uttoxeter
Hi Guys
I am new to this forum and to GE Fanuc so hopefully you can help me.
I have the code (as a zip archive) for a GE Fanuc 90/30 PLC but I have no idea what version of Proficy ME the software was written in.
I have opened the software by restoring it in both version 6 and version 8 of the proficy ME. It has opened up fine in both, and I can view the code.
Is there a way to find the version the software was written in and the firmware in the PLC? Or can you use any version to edit it?
Cheers
Since you could open it in version 6, it must have been written using version 6 or earlier. Once you save it with a newer version you won't be able to reopen the saved copy with older versions. A project can be opened with any version equal to or newer than the version it was saved in.
To find the version of firmware in the PLC, go online and look under the "Target" menu, "Online Commands", "Show Status".
If you are coming to GE from Control Logix or Compact Logix, be aware that the firmware version in the CPU does not have to match the version of Proficy Machine Edition.
Quick question what is the software package to program GE-Fanuc 90-30 controllers the version I had before was The dos LM 90 version and as I lost...
40
52,521
Hello, Would anyone be able to help me find a copy of Logic Master 90 Software? I need this for a conversion. I have a printout of what is in the...
775
Hello, Does anyone have LogicMaster 90 software? I need a printout of a PLC project from a GE Fanuc 90-30. I have the project just not the...
1,158
Years ago, we had a PLC-5 here running some "Supervisory" Utilities Logic. It had (still has) a Wonderware front-end. It was reading multiple...
3,611
Need to find where to get VersaPro or Proficy software for the GE Fanuc 90-30 PLC.
2,525
