Crimson 3 - Configure, trend and data logging & zoom level for display editing
whussain6
Oct 2013
Newcastle
108
Hi guys
I have Productivity Station which will collect Run time data from Phoenix input block "ILB ETH 24 DI16 DIO16-2TX". I am new to crimson and have Crimson 3.0 (Gold Build 582.001). I have to do following:
1- Using productivity station calculate Run time for which a digital signal from phoenix stayed on and number of time it turned on.
2- Log data for few shifts and display on monitor via HDMI cable and on cell phone through internet.
3- Show trends of Run time of the machines on monitor.
I am not very good in C - Programming. Any help and suggestions about configuration and setup will be appreciated. Thanks
another question please, I am preparing display which I am planing to use on monitor which will be connected to Productivity Station via HDMI port. When I open display tab in Crimson 3, it shows "Note:Editing is not fully accurate at this zoom level". I checked, it is fully zoomed out from crimson software. I wonder if it is related to my laptops display settings?? Thanks in advance
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
114
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
170
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
105
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
89
Has anyone setup communications with Red Lion 3.0 MODBUS to Baker Hughes Centrilift GCS VFD? Thanks
89
