8 Pin Mini Din connector on Allen Bradley-RS-485 comms
Go with the PM02 cable (or geniusintraining’s equivalent). It was meant for Allen Bradley’s proprietary communications port and you’d be hard pressed to get into any trouble with it (some devices use the port for power and if the pin is grounded it can damage the PLC). There are a couple of connectors out there that “kinda” fit (Apple used to make one) but again, the PM02 cable fits and is wired correctly.
P.S. I’ve used a PM02 on a Micro830 for Modbus RTU communications and it works just fine.
I know it has been a couple weeks, but if anyone is still looking for the cable Geniusintraining does have the right cables just a couple months ago he helped me the same cable that the OP was looking for.
It had all pins landed furthermore I took this cable and made it into part of a "Y" cable to connect to and utilize a Red Lion Kadet's dual serial port, works good
Edit: had the correct plug to no jamming the dimples in or shaving them off
dlweber, thanks for the update, glad it worked out for you
kittydog42, next time give mine a chance, it will save you a few bucks and you dont have to force them
Im having to re purpose some old PlantLinc 580 wireless IO extender boxes. Im having a little trouble trying to find a cable for them. The...
2,082
I am looking for 8Pin mini-Din male connectors. To attempt to make my own cables. For FX PLC's the ones I have been seeing the pins are not the...
1,902
Hiii, I want to communicate MGate MB3180 to my ML1400 channel0 configuration as my ML1400 as Modbus RTU master. But i need pin configuration for...
1,740
That is, do all PLCs that use 8 pin mini-din for connection to PG use the same 8 pin mini DIN? In case I'm using non applicable terminology, I...
25
11,220
Guys, Does anyone here know a better/easier way to fabricate a 8 pin mini din cable? I'm using it for Mitsubishi FX1 PLC to Proface HMI. The...
11,175
