Change FB number on Know How protected Function blocks - TIA Portal
rQx
Oct 2010
Trelleborg
1,051
Hi!
I have downloaded sample functionblocks from Siemens, they are know how protected. I want to use four of these function blocks. Problem is that when I insert a FB from the libraries or just copy the one in the project the FB number wont change and I can't change it because it is protected. Any clues?
/Tim
When you say you want to use "four of these function blocks", do you mean you want to call the same FB four times?
If so, you can simply call it in your code in four different places, and use different parameters and a different instance DB for each call.
I have a FX5UJ-40M that I am struggling to change the port number. I open up the ethernet configuration program, add the 'SLMP' device and add my...
424
I am replacing a PanelView Standard with a PanelView Plus 7. The application is used for our production lines to order supplies from our...
3,253
I'm sure this is an easy problem to solve, but so far I haven't found the solution. I am looking to trigger a screen change using a word. I...
4,208
How do you change the processor node number on a Micrologix 1100 using a serial cable and AB_DF1-1 driver?
1,814
Simocode DP is ship with node number 126. That node number is over node number of profibus DP (Max = 125). How can we change default node number...
5,026
