pittlei
Hi, I am new to PLC with computer science background in scripting. I am very lost in the ladder logic here.
I took a 5 seconds video clip since I can not upload here.
https://drive.google.com/open?id=14tHLuyQXKtGYpJpjEsPjXMOTcQQq6aYI
here I have a very simple ladder diagram :
rung 0 : left side: XIC , right side : MOV: test1 to result1
rung 1 : right side: CPT result1 = 1000
rung 2 : left side: GRT result1 > 90, right side : testlight
rung 3 : right side: CPT result1 = 2000
for the variable above, test1=0 is real , result1 is real and testlight is bool
observation:
1. the result1 value remained at 2000 most of time and changed to 1000 periodically (shown in the video )
2. the testlight in rung 2 is on all the time
3. if I changed rung 2 to GRT result1 > 1500, the testlight in rung 2 is off all the time. ( though the result1 value was shows as 2000)
Question:
what are the values shown on the ladder diagram ? for example, result1 in rung 0 should be 0, result 2 in rung 1 should be 1000, and rung 2 should be 2000. Why results in all rungs show the same value as 2000?
thank you
observation:
Question:
thank you
