Omron C200H
Donnchadh
Jun 2002
Ireland
1,004
Hi
I have been asked to do some changes to a Omron C200H CPU 21 and a CPU 01
Plc.I was hoping some one could point me in the way of a cable
and maybe what soft ware I would need.I have cx prog but I do not know
if this would do.
Best reguards
Donnchadh K
You will require a 3G2A6-LK201E Host Link Module. If there is a card mounted next to the processor you may also require a BP-001 or BP-002 extender for the Host Link. If you have thoase things, post back here and I will put you in the direction of documantation to make the cable.
Try E-Bay. These things are often on there.
Paulus, it will not fit one of these old dears. It will only fit from the C200HS onwards.
šŸ™ƒ
Ah, how right you are Bob, (sorry Donnchadh).
Although this cable will fit in the peripheral port, the port itself cannot be used to connect via CX-Programmer (or Syswin).
Thanks for the catch Bob :)
No peripheral port on a C200H Paulus. Only a long slot to take the Host Link as described below. Peripheral port came in with the C200HS. I sold the things for some years. Sold Hitachi, TI, etc etc as well. Interesting!
Hmmm...
I've got a C200H CPU01 sat here on my desk, with a CIF01 cable sticking out of its peripheral port. :cool:
Are you maybe thinking of the C1000 / 2000H. I've just had a look at a couple here (1 of which does have an LK201 adaptor fitted), and they do only have the adaptor slot.
Perhaps we should start another thread on this one... :)
I have a sysmac omron plc C200H CPU01,only the power led is ON,using CX-ONE programmer software, and connecting to the plc via Host link LK202-V1...
689
In order to upgrade a control unit, we need to backup program of an omron C200H CPU01 with host link LK202-V1 that has RS422 D9 Connector. Please...
621
The logic seemed to convert nicely, and I had to make changes to the addresses for my AD and DA and 32-point input cards. The current problem is...
1,028
I am trying to display some scaled analog input values on a C-more Micro terminal, from an older C200H Omron PLC. The addresses appear to simply...
2,144
I have a customer with the Omron C200H that occasionally will start flashing the alarm light and the machine stops. They say they can power down...
2,878
