Mitsubishi PLC modbus tcp communication to 3rd party redundant plc
kevinlin_5
Mar 2016
Singapore
Dear all,
I have a problem with the Mitsubishi PLC modbus tcp communication. I'm using a L26CPU and LJ71E71-100 ethernet module to perform a modbus tcp communication to siemens S7-416H redundant PLC.
In the ethernet module's network parameter setting, I setup 2 siemens plc's IP address and port No in 'Destination IP Address' and 'Destination Port No.' column in open setting, and I also set 2 protocols for write and read respectively in the predefined protocol support function of the ethernet module.
But when I start my plc, I only can get Siemens plc1 connected. There is no attempt for the Mitsubishi plc to connecte to the Siemens plc2. Did I missed any setting for the plc2 configuration?
Thanks for the help.
Hi hope all are ok. I have mitsubishi PLC Q03UDV CPU. I have control a drive through modbus inteligent module QJ71MT91 in GX Works2. Any experts...
614
Hello, I would like to establish Modbus TCP connection between FX5U and PC computer. Mitsubishi FX5U will be Slave, PC computer will be the...
8,556
Hi everyone! I would like to establish Modbus TCP connection between FX5U cpu and another PLC (other maker). And the FX5U will be the client. I am...
21,198
Hi, Does anyone come across any Mitsubishi PLC (except A series) that can communicate in Modbus with DCS? Appreciate your feedback. Thanks...
4,544
Dear PLcs.net members, Does any body know about Mitsubishi PLC FX2N can work with modbus (communication) or not? Where I can find some...
19,363
