fairfaxjim
I am trying to convert an Omron Syswin 3.4 format program to CX-Programmer, and then convert the PLC type within CX-programmer. I first converted the C60H PLC to a C200HG within Syswin. I then successfully converted the Syswin C200HG ladder program to a CX-Programmer .cxt text file using the conversion utility, then saved it from CX-Programmer to a project .cxp file. I am now attempting to import the data memory file (*.ddm) from Syswin to the D data window in the converted CX-Programmer. Since the Syswin .ddm file has data memory as DM, and the CJ1 uses data memory as D, I get a "The file contains an entry for "DM" which does not exist on this PLC/CPU type" "These memory areas will not be displayed."
I have even tried to hack the header in the .ddm file to change it from DM to D, without success. Since Syswin doesn't have any PLC types that use the D for data memory, I can't simply fool it by changing the PLC type and resaving the data memory.
Anybody got a clue if I can get DM formatted data into a D formatted PLC?
Gotta love that Omron and their half way conversion program.
