GE LM9070 cannot file changes
jdbrandt
Oct 2002
Pennsylvania
1,203
Any LogicMaster 90-70 guys know about this one?
I attempt to edit a rung ONLINE,and receive the
following messages:
(S44) Requested PLC operation failed
(S47) Insufficient PLC user memory for completion
If I insert or modify a rung, no problem.
So, this is my workaround.
And, of course, i have plenty of memory.
This is a CPX 772 processor.
And, I´d normally call GE support, but I´m in
the field (to say the least), and telephone service
is not exactly close at hand, cheap, or reliable
enough...
The way the 90-70 handles changes while the processor is running is to first download the program block to available memory and then change the 'start of program' pointer. That way it can take as long as it needs to download without having to interrupt program execution and I/O updates.
There are a couple of possibilities. First, if your application is one large _MAIN program (no subroutines), and you've used more than half of the avaliable memory in the CPU, you don't have enough memory left to download the modified program while the original program is still running. Even if your application is broken down into subroutines, if the size of the subroutine to be modified exceeds the available memory, you'll have the same problem. If you have been doing a lot of online modifications, the memory can get fragmented. The 90-70 does a defrag when you perform a program download while the CPU is stopped.
perish the thought
Steve...now really, who writes all-in-one _MAIN anymore???
Seriously, thanks for the info. You are right, in that
downloading does solve the problem.
The thing that is a mystery is that my program and data
table is about 50k, and the total memory is 512k.
Yes, my subroutines are large, and, maybe thats the prob.
Anyway, plcs.net comes through again...
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
128
Hello Friends I have a backup that I am trying t open in mi PC (RSLogix 17.01) and I get this message. I have read many posts and done many...
167
Hi, Im trying to open an old old Siemens WinCC project. It doesnt have to run i just want to look at the project in WinCC explorer. Its...
666
Hello. I cannot change the SendClock settings for a PROFINET IO device. I need to slow down the CODESYS PROFINET IO controller. What am I doing...
198
Hi, I received the following project from a customer on a QuickPanel Proface 6" that I need to swap to a Siemens Panel. However, I cannot seem to...
335
