ryang112
Hi there everybody
I have a project in WinCC Flexible 2008 SP3. I am trying to add values to a SQL stored procedure. The stored procedure does work if I use hard coded values instead of parameters (I am attaching a screenshot)
I am calling the stored procedure from a VB script and it runs whenever a value is changed/updated. You will notice I omitted the other 3 parameters for the simple reason that it keeps crashing on the first parameter, so if I can solve that issue I can insert the others. I am getting an error on the second error loop (please see screenshots of the script and the error)
Does anyone have any ideas, i have tried a few approaches as far as the script is concerned and am at my wits end. Any input would be greatly appreciated
Thanks for taking the time to read this
