Controller Link Question! Omron cqm1h
arist
Nov 2003
I need some help about data link table configuration (DM) in the controller link module of cqm1h .
I read the programmer manual of cqm1h, and I made the example, but I can't write in the DM6400, this is a memory for read but not for write, I need to know in what program i can make this..
Try this:
DIP switch 1 must be OFF
Change PLC mode to stop/programing and then write to DM read-write area.
This is possible with syswin3.4 or cx-programmer.
Hi, i'm trying to make a red with two plcs omron cqm1h by controller link communication whit automatic datalink, but I was trying to configurate the DM6400, for two nodes, but the module shown the led of link intermittent, I need to know the correct configuration for the DM, I wrote the following configuration but i don't know what was wrong.
DM6400 0010
DM6401 0000
DM6402 8600
DM6403 0010
DM6404 1000
DM6405 8200
DM6406 0200
DM6407 0001
DM6408 0003
DM6409 0000
Hi Guys, Has anyone ever worked with an IAI robot cylinder position controller PCON CA and if so can you help me on how to program it with...
2,588
D
Hi I have come across a Small problem in my Network Set up, it consisits of a CS1 rack PLC with 2x Controller links and 1x Ethernet unit called...
5,203
I have a controller link support board for ISA PC bus (3G8F5-CLK01 V1.00). The support board installation is Ok and the setting too. The RUN...
4,036
30
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
32
