Basic Arduino Question
24V
Jan 2019
Canada
Hi everyone,
I am new to Arduino and am interested in purchasing one for a project. Unfortunately, the Arduino Uno will not work for me as I require more digital inputs/outputs (roughly 20). Which basic Arduino board can provide me with this? I was looking into the Arduino Mega 2560 Rev3 but wanted to confirm before purchasing it.
Kind regards,
24V
Hi everyone,
Kind regards,
24V
What are you connecting to those pins? 5V? 24V?
The question was because if you needed to interface with a different voltage, you would require another chip or relay and could use an expander instead. Something like 25017 from Microchip.
If it's all 5V, then you're better off with a Mega.
Honest question, what uses does this Arduino have on an industrial machine? I see lots of people asking about them, but I can't think of a place to use them.
They generally don't. They are fantastic little devices, and they are cheap, but they don't have the support structure that more commercial devices have. You also can't just wire up IO, you have to provide the supplementary circuitry provided internally in most controllers. Lots of similar reasons. They do, however, have some use. Say for some reason you want to track how often or when something happens, you can customize a small pi or arduino and handle the situation, so you can solve little 1 off programs quickly.
Thanks for the response, makes feel a little less out of the loop.
And, for PLC inclined people, there is no such thing as going online with it.
Hi all, I have a noob question regarding data handling from sensors. I understand configurations and I/O mapping sensor input/output variables...
218
Hello I am new here and new to PLC's, I wrote this program for a class that I am taking and my local tech school. The description is switch 7 will...
410
1,965
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,066
Hey Programmers, Heres todays puzzle I was trying to solve... I have a Modbus TCP network with two Modicon M221 controllers live on my work bench...
466
