Mitsubishi Modbus TCP (Predefined Protocol Support Funtion)
There is manual called "Mitsubishi iQF FX5 User's Manual (MODBUS Communicatio)" <JY997D56101>. You have there detailed explanation.
Dear all, I have a problem with the Mitsubishi PLC modbus tcp communication. I'm using a L26CPU and LJ71E71-100 ethernet module to perform a...
3,934
Hello, I would like to establish Modbus TCP connection between FX5U and PC computer. Mitsubishi FX5U will be Slave, PC computer will be the...
8,556
Hi everyone! I would like to establish Modbus TCP connection between FX5U cpu and another PLC (other maker). And the FX5U will be the client. I am...
21,198
Hi there. I am after a bit of guidance on connecting a Mitsy Q03UDECPU ( on board ethernet) to a Modbus TCP slave. I am using GX Works2. The...
2,503
Hi everybody, I want to connect a mitsubishi FX3u plc to a master modbus plc through ethernet. does FX3u-ENET module support that ? Thanks
6,707
