Pearson Packaging Systems - Would you recommend them ?
Cydog
Feb 2018
Maryland
313
Good Morning ,
I have worked with many robot integrators through the years ,and was looking at Pearson Packaging Systems . Have many of you used them in the past ? Would you recommend them ? A few questions....
- Do they work with and listen to you on System Design ?
- Do they accommodate you with the parts that you want them to
use , such as the same PLC's ,sensors , drives,that will give you spare parts continuity throughout your plant ,
within reason ?
- How is their service and response time ?
We are thinking of using them on a large project.
Thanks so much and have a great day .
I don't have much to contribute here, but a few times in the past few years I have worked on a small Pearson machine that was built in the early 2000s and was able to call tech support and get pretty good troubleshooting assistance for free. They still had the original programs, schematics and an understanding of the machine, which I'm sure is obsolete at this point.
Pearson aquired a company called Flexicell based out of Richmond Virginia.
So I think they use Flexicell for anything on the east coast.
They will accommodate anything you want but might be an upcharge for certain items. We had some trouble when they first took over Flexcicell but I think most have been rectified now.
Also look into Sentry Equipment based out of forest va. (Lynchburg).
Been to both facilities.
Shoot me PM and I can give you some names.
Is Pete Lawton still the controls engineering manager at HQ in Spokane? Pete and I worked together for a long time and used to raft the Lower Salmon River in the summertime with Tim O'Connor and Nick Henry.
When I worked with them, Pearson was a very strong A-B user, so it would take some significant money to make them vary the controller, but probably a little less to get them to vary sensors.
For safeties sake make sure if there robot is told to move to a point and does not make it, that it goes to a safe place or just releases all movement. A lady at a plant I work at pushed her way passed the safety gate (stupid mistake but still..) to get a box off the conveyor. The robot came over to pick it up but she was in the way and it pinned her to the conveyor and she suffocated to death. If it had seen it didn't make it and moved or just shut off she would still be alive today.
Hello, We have a mechanical packaging machine ( horizontal flow pack machine ), which the OEM is no longer supporting the spare parts. The...
2,218
Hello guys, Seram Fairy is machine for packaging. We use this machine to place peanuts in small bags. But old equipment doesn't work anymore, so...
1,415
I have a horizontal Packaging Machine. this is operated by two Delta drives one is S series and one M series. I already synchronize these two...
1,908
Good morning dear friends, can you help please provide me with a 7 step program serve for filling and packaging of the food industry as an example...
2,528
hi i need your help I have a Mitsubishi FX3U plc and screen GOT1000 16 .. I have two Scales, and two load cells METTLER TOLEDO IND110 I want to...
3,973
